aaP_bilgicise How to add SSL using API i use this url But not Work /acme?action=apply_cert_api In Doc API no method to add SSL using API Thanks
aaPanel_Kern Hello, it is recommended that you obtain it from the developer mode of the browser. aaP_bilgicise
rid3xyoy aaP_bilgicise I also use API to add sites and other, if you want you can write to me at info[at]adresi.bg to exchange experience.
rid3xyoy aaPanel_Kern Something similar can be used in Webhook if exist /www/server/panel/pyenv/bin/python3 -u /www/server/panel/class/acme_v2.py --renew=1
aaP_bilgicise aaPanel_Kern I dont Understad What you mean, Should you tell detail Step By step to add SSL via API I test manual via terminal but not work curl -X POST 'https://xxxxx.panel00/acme?action=apply_cert_api' \ -H 'Authorization: WSEHp80secretttu5lsRkAYFw5k0klDF51E' \ -d 'site_id=37&email=your-email@example.com&www=true&csrf_token=my_csrf_token_here'
