aaP_bozadaj4 I also try to reinstall and how to eliminate the python environment I see in my vps there are 1.1gb residues in the www folder, and applications such as bt-mysql57 and bt-php81 after uninstalling aapanel.. some way to uninstall it completely I want to reinstall it cleanly since I had errors in the first installation
aaPanel_Kern You can directly delete the directory of related programs, please back up before deleting. aaP_bozadaj4
aaP_bozadaj4 aaPanel_Kern I already deleted it but apparently it is not completely deleted, I no longer have space I would like to eliminate it completely in the first installation I had about 3gb of space left over now nothing I think there are more residues around
aaPanel_Kern I suggest you restart the server once, is it normal? If it is not normal, please use the command to check what directory takes up space aaP_bozadaj4
aaPanel_Kern Overwriting the installation will not lose data, but will only change the aapanel username and password.
aaP_OkeBayar @aaPanel_Jose untuk menginstal dan menghapus aapanel di almalinux 8 perintah nya bagaimana
aaPanel_Kern Hello, what problem did you encounter? Can you elaborate or take screenshots? You can install it directly using the installation script aaP_OkeBayar
aaP_OkeBayar @aaPanel_Jose @aaPanel_Kern I use almalinux 8 and installed aapanel using a script on the web but when there is a link it can't be accessed
aaPanel_Kern Hello, please check whether the system firewall and server provider's security group have relevant ports open? Can you use this command to check if aapanel is running properly? curl -k https://www.aapanel.com/script/aapanel_check.sh | bash aaP_OkeBayar
aaP_informatikamandua Hello @aaPanel_Jose, i want reinstall my aapanel on my old server. I just want to refresh back it to earlier function, and no other. Is i need to setting this page ..?,
aaPanel_Kern Hello, aapanel can only install the latest version. Settings cannot be restored aaP_informatikamandua
aaP_informatikamandua aaPanel_Kern If we choose same setting here, is our web server back again ...?, or next must setting up menu in web server, database and others ...?
aaP_informatikamandua If we choose same setting here, is our web server back again ...?, or next must setting up menu in web server, database and others ...?
aaPanel_Kern Hello, you can install the relevant programs directly in the app store aaP_informatikamandua
aaP_imogiridigital I'm reinstalling my server and then I reinstalled aapanel, but I have this problems
aaPanel_Kern Hello, please check if you are using the correct link to access? You can use this command to check curl -k https://www.aapanel.com/script/aapanel_check.sh | bash aaP_imogiridigital
