When migrating the web I get the following error. I've already tried to delete the web that gives the error and look for the file it mentions and if I have it, could you guide me? Thank you.
ERROR
"Failed: Site [cemuva.com] failed to create, ERROR: An error was detected in the configuration file. Please solve it before proceeding
nginx: [emerg] open() "/www/server/panel/vhost/nginx/well-known/masnutricion.com.ar.conf" failed (2: No such file or directory) in /www/server/panel/vhost/nginx/masnutricion.com.ar.conf:11
nginx: configuration file /www/server/nginx/conf/nginx.conf test failed"
    Hello, thank you for your feedback, this is a known issue
    You can compress and download the /www/server/panel/vhost/nginx/well-known/ of the old server, upload it to the same directory of the new server and decompress it, and finally check whether the file is the same as the old server
    and then migrate
    segnotec
