aaP_lukas I want to backup my Databases to a remote storage and for that I installed "FTP Storage" from the App STore. But my FTP Server requires FTPs. What do I need to do to make it work?
aaPanel_Kern Hello, you need to configure FTP Storage. FTP Storage needs to connect to the FTP server. aaP_lukas
aaP_lukas aaPanel_Kern Ok but how. I Use FTPs and not SFTP. If i enter all data it does not work: If I use for example curlftpfs I have to add the following parameters to make it work: ssl,no_verify_hostname,no_verify_peer
aaPanel_Kern Hello, what information is prompted when adding? If it cannot be added, it is recommended to change to other storage such as aws Google aaP_lukas
aaP_lukas aaPanel_Kern this is the error message: The FTPs Storage is a local NAS. I am able to connect to it via FTPs with WinSCP and so on.
aaPanel_Kern Hello, if you confirm that the user and password information are correct, it should be caused by incompatibility. aaP_lukas
