mzm Is there any instruction to install ngx_http_secure_link_module ? I need this module for Nginx. Thanks
aaPanel_Jose mzm download the install file wget http://183.235.223.101:3389/install/0/nginx.sh edit the config add compilation parameter --with-http_secure_link_module For example, I need to add in nginx 1.17 . 3.run install sh nginx.sh install 1.17
mzm Thank you for your reply. Is it possible to add module after Nginx installed or it must be started from fresh Nginx installed?
mzm Working great. Thank you. This is a great panel ever I have found and hope to get more features in future updates. Cheer! 😀
Bimoldas Bro how to install it in 2024 with any nginx version atleast any latest version. thanks in advance
aaPanel_Kern Hello, are there any problems with the installation? You can check what caused the installation log: /tmp/panelExec.log Bimoldas
