• Support
  • OpenLiteSpeed and aaPanel vhost
How do I get aaPanel to work correctly with OLS? It doesnt seem to map the virtual host when you create a new domain or wordpress site. It defaults to /www. I know where to change the default site directory setting in the global panel settings but I am not sure how to set it up so that it creates the proper vhconf.conf files for each domain etc. in OLS. Other control panels do it automatically, I am sure this does as well but I have no clue as a newbie.
    aaPanel_Kern I figured it out, the problem was that OLS was pre-installed prior to installing aaPanel. After removing it and reinstalling OLS thru the aaPanel App Store it maps fine, but does virtual mapping with OLS much different than other panels.
