Hi,
How do I change phpmyadmin port from command line?
Best regards,
Hi,
Best regards,
Hello, what web service do you use? Please modify the port used by the web service phpmyadmin
I needed it to be via the command line. I have some docker panels and I needed it to go up with a different port than 888 and ssl 887. Because cloudflare doesn't allow it
Hello, you can only modify the corresponding configuration file, or modify it from aapanel's phpmyadmin
That was my question... what is the path to this configuration? Is it on nginx? or in phpmyadmin itself that changes?
If you are using nginx this is 887's /www/server/panel/vhost/nginx/phpmyadmin.conf
888: /www/server/nginx/conf/nginx.conf
Hi,
This is useful but could you say where is it in the apache and ols please?
I'm using the 3 web servers.
Best regards,
Edited... I will need the ports
/www/server/panel/vhost/apache
/www/server/panel/vhost/openlitespeed
