aaP_siru.khan I m getting a '404 Not Found' error when trying to access post and page (only home page opening), What could be the potential causes for this, and how can I resolve it?
aaPanel_Kern Hello, suggest you check whether the URL rewirte of the website needs to be configured? aaP_siru.khan
aaP_siru.khan aaPanel_Kern i have fixed a code that needs to be pasted in config. One more thing How to install SSL on aapanel itself.
aaPanel_Kern Click on the website to view SSL Aapanel's SSL is available in the settings aaP_siru.khan
aaP_siru.khan aaPanel_Kern I have turned on Panel SSL but still not fixed. kindly give me comprehensive step by step reply so that I can resolve the issue.
aaP_siru.khan I have turned on Panel SSL but still not fixed. kindly give me comprehensive step by step reply so that I can resolve the issue.
aaPanel_Kern It is recommended to indicate that the SSL certificate you use is for the domain name? If so, did you use a domain name when you visited? By default, aapanel uses a self-signed certificate. If the browser does not trust the self-signed certificate, you can refer to the following tutorial. https://www.aapanel.com/forum/d/15210-aapanel-enable-panel-ssl-use-self-signed-certificate-browser-add-secure aaP_siru.khan
