Hello! I would like your help. I have been using aaPanel for about 2 years, where I have several websites but with PHP. Now I want to try out CMS in node.js. I would like to know if it is possible to install Ghost and Strapi from the Node Project module that comes with aaPanel. I haven't found much information about that. Thank you for your answers.
Installing Ghost and Strapi on Node Project in aaPanel is possible?
Hello, currently some programs in the Node project may not be deployed and started. It is recommended that you try it once. If it cannot be started, it is recommended that you manually use the command line to deploy it.
aaPanel_Kern I understand, then I could do it via docker, I guess it would also be the same with installing odoo community. Thanks a lot!
