Hi there. Installed panel and everything was fine with IP address. I had binded domain, then it said "this site can not provide secure connection". Ran bt restart and bt 16. Then ran bt 22 for log.
Here is the log:
EXECUTING
<gevent.socket3.socket at 0x7f342f544950 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02&\x01\x00\x02"\x03\x03Î\x07|àá|Á\x05ët½\x90\x1b9÷2\tË\r\x04\x9cÊQ91ãä¢cÞ\x00 \x7f(Û\x9fþ?ö\x01\n'
<gevent.socket3.socket at 0x7f342f2f33b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03Ì\x89\x11çV\x91¨ýÖM\x00ª¬áRÑ:\x1d\x8cÌïÀ&\x07\xa0¿ 2©ú ú»\x8d\x85÷üà<9Ð\x96®»êa\\x06Ôñ\x15\x9e\x98\x91\x08üèKþófä\x91\x00 jj\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93ºº\x00\x00\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent.socket3.socket at 0x7f342f5449b0 object, fd=6, family=2, type=1, proto=0>: Expected GET method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03ÛP?ó\x06a»RùçÈ\x00\x8fõAKI\x08\x98\x9b@ûîù:§÷ïÿ1UE \xadQ®\x81ùj"NÅËW\x8d\x92)#âó\x98\x16h{²0V\x8fð¼ÝO\x00üq\x00"ªª\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x00\n'
<gevent.socket3.socket at 0x7f342fac8d10 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x99ì\x8f\x00±\x96T«$_×Ób¼\x1bDÏ\x9e¾¸\r[_ç«îÒVÆy» ñ#΢)I\\*ýÂ^\x8dä\x82Ò\x7f\x12>ü¾ùp+]ANþ\x830\x975ô\x00 \x8a\x8a\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93jj\x00\x00\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent._socket3.socket at 0x7f342f544950 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x1f-\x02¯»\x01W~·ÁB\x0e
5U\x0e8qȯ&ó\tå½a¤ñ#Ç/\xa0 9Å·ôKXÎOæOEßID\x93\x1bj\x0e$À\\x88ÇÏÔË\x9cÂ}\x05ð\x00"\x1a\x1a\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x00\n'
<gevent._socket3.socket at 0x7f342f2f33b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03Ý\x9d·_³^VkuÑ6ü\x8e\x0c?\x82ð\x08\x8c ä\tH°ÐpK\x84ã;ÙN L¥\x9fYör\x8d ÝJÐ&Oqb\x86å\x91\tU¼,=ÒáÑ.\x9d\x1e\x99|§\x00"êê\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x00\n'
<gevent._socket3.socket at 0x7f342f5449b0 object, fd=6, family=2, type=1, proto=0>: Expected GET method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x14øy@!6m\x06Ã\x91*H\x90\tG©\n'
<gevent._socket3.socket at 0x7f342fac8d10 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03Ë\x87&§{õø#\x07Ê\n'
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 666, in handle_one_request
if not self.read_request(self.requestline):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 531, in read_request
raise _InvalidClientRequest('Invalid HTTP method: %r' % (raw_requestline,))
gevent.pywsgi._InvalidClientRequest: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03H{Ao\x9d\x86HIËJ:\x03%\x90¡\x80\x03\x8b¹\x0cøþX*m\x03\x81.åÌZR ÄÍ\x8cs\x03\x1a@\x90É\x13ý8áÉ~ç\x0fH\x13å)µÖÎ\x8e3\x03
\x9bîI©\x00 ªª\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93\x8a\x8a\x00\x00\x00\x00\x00\x12\x00\x10\x00\x00\rscratch.media\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 569, in log_error
message = msg % args
TypeError: not enough arguments for format string
<gevent.socket3.socket at 0x7f342f544950 object, fd=6, family=2, type=1, proto=0>: "Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03H{Ao\x9d\x86HIËJ:\x03%\x90¡\x80\x03\x8b¹\x0cøþX*m\x03\x81.åÌZR ÄÍ\x8cs\x03\x1a@\x90É\x13ý8áÉç\x0fH\x13å)µÖÎ\x8e3\x03\\x9bîI©\\x00 ªª\\x13\\x01\\x13\\x02\\x13\\x03À+À/À,À0̨̩À\\x13À\\x14\\x00\\x9c\\x00\\x9d\\x00/\\x005\\x01\\x00\\x01\\x93\\x8a\\x8a\\x00\\x00\\x00\\x00\\x00\\x12\\x00\\x10\\x00\\x00\\rscratch.media\\x00\\x17\\x00\\x00ÿ\\x01\\x00\\x01\\x00\\x00\\n'" ()
<gevent._socket3.socket at 0x7f342f2f33b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03t|dZm5:kÊH\x02â®\x87\x97WM\x85Xsñæy<\x8cä}×Ó¶¢ÿ ú\x9c÷̸\x9d\x0c\x12\x1f@µÚ/§<þ\x04Û\x8f\x80IUy\x18ÀÎã<!,\x9fc\x00 ªª\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93\x9a\x9a\x00\x00\x00\x00\x00\x12\x00\x10\x00\x00\rscratch.media\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent._socket3.socket at 0x7f342f5449b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03(Ö\x07O\x12\x144qÓu\x7f\x04:ä³\x9f\x9f\x00Äèoè&º¼ø\x8e\x93ïDàá ~\x1f+²\x87åÄVâñ¿\x0ccÇ?CÆÙú\n'
<gevent._socket3.socket at 0x7f342fac8d10 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03ô0\x8f³B\x9d÷×ó\x92Â/Ò?S\x93\x11\x0e¹õaàz\x8el¤ÁÆ4Q"Å Íq\x10Ù\x08ï\x1c\x8d7Ð7\x99\x14H\x96·\x86Ã\x97\x1akâ¬\x96FÇËö¢\x802(\x00 ::\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93ÚÚ\x00\x00\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent._socket3.socket at 0x7f342f544950 object, fd=6, family=2, type=1, proto=0>: Expected GET method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03#OTÁ\x06.\x01«×\x8du\x96¶\x0bÍ@",Î\n'
<gevent._socket3.socket at 0x7f342f2f33b0 object, fd=6, family=2, type=1, proto=0>: Invalid http version: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03yðIèX+k\x7f\x86\x00J\x14\x85?\x99ê\x13O(\\ä>ªí\x1bÎN)\x9eþæ\x01 \x17\n'
<gevent._socket3.socket at 0x7f342f5449b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x9a\x02Ú\x0e\x90¹\x80ûK<z¥\x94L\x7faä\x7fn\x0cÓæľQ®ù\x8eÚ\x08½Ü \x9bÇó\x929²5é?ö\x04AaSU¬l\tó\x86UiO\x17°\x15\x9f\x03íõ]É\x00 êê\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93ÊÊ\x00\x00\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent._socket3.socket at 0x7f342fac8d10 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03§j9\x90·\x8dîP~T\x16\x12Þ\x863\x99ÿA-\x7f\xa0=\x9bN*´\x80»µ´\x1e\' \x95ú\x00\x98į\x14"\x98&\t¢Ô\x7fÁ\x9b7|\x0bê:3¹\x81Åà]Í9-ÖM\x00 JJ\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93\n'
<gevent._socket3.socket at 0x7f342f544950 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x14D\x9eQ<\x12\x82Ñ7\x1b3í_Ò\x8f¿\x021\x1b¢lõ\x03YÌ\t
q(fWt åù9ôÒROa1\x82NÑR§=p(;þjÂnD\r\x0bRâ\x0c&ìy\x00 \x8a\x8a\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93êê\x00\x00\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n'
<gevent.socket3.socket at 0x7f342f2f33b0 object, fd=6, family=2, type=1, proto=0>: Invalid http version: '\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03\x89KGS\x1e\x85ékñ¿±Äi]0jÉ\x12ΧçQ\x10ã7\x12\x98\x9c\x95á? ¡\x9aD©O\xadÜàlsú\x95H\n'
<gevent.socket3.socket at 0x7f342f5449b0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: "\x16\x03\x01\x02\x00\x01\x00\x01ü\x03\x03½y·R\x99dé'\x87÷\x0b\x8b\x8bjU:YK3²\x0b\x04ëÌà(½'~|Y Ü#\x98ã\x1céæyÊ«p|\rlîÙRyÞ¾VÚ\x95\x81T\x02[P(Ý\x08\x1e\x00 **\x13\x01\x13\x02\x13\x03À+À/À,À0̨̩À\x13À\x14\x00\x9c\x00\x9d\x00/\x005\x01\x00\x01\x93JJ\x00\x00\x00\x00\x00\x12\x00\x10\x00\x00\rscratch.media\x00\x17\x00\x00ÿ\x01\x00\x01\x00\x00\n"
Can anyone help please? Thanks
