I changed the ssl certificate in the settings after installation and then lost access to the panel. How do I reset it?
bt 22 log:
`root@94:~# bt 22
EXECUTING
[2024-09-03 04:52:27][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/class/panelPlugin.py", line 2259, in a
return public.run_plugin(get.name, get.s, get)
File "/www/server/panel/class/public/common.py", line 8210, in run_plugin
raise PanelError(res['msg'])
public.exceptions.PanelError: An error occurred while the panel was running: Traceback (most recent call last):
File "/www/server/panel/plugin/dns_manager/dns_manager_main.py", line 1365, in set_soa_record
get_file = values['domain'] + ".zone"
KeyError: 'domain'
File "/www/server/panel/BTPanel/__init__.py", line 2542, in publicObject
File "/www/server/panel/BTPanel/__init__.py", line 2488, in run
File "/www/server/panel/class/panelPlugin.py", line 2261, in a
return public.get_error_object(None, plugin_name=get.name)
File "/www/server/panel/class/public/common.py", line 1266, in get_error_object
result = readFile('{}/BTPanel/templates/default/plugin_error.html'.format(get_panel_path())).format(
KeyError: 'plugin name'
[2024-09-03 04:52:31][DEBUG] - Traceback (most recent call last):
KeyError: 'domain'
KeyError: 'plugin name'`
