I use Cloudflare. Do not use reverse proxy or redirect.
Using .cyou TLD
I recently migrated my server using One click migration tool. My server has around 600+ domains.
I copied /www/server/panel/nginx directory from old server to new one and also copied the SSL folder from /panel/ssl the older server.= to the new server.
First I got this problem:
I reinstalled pyopenssl.
However, SSL is still getting stuck on verification type: http -01
and now the 404 error.
I am able to issue SSL in 3-5 retries. The process is very slow and the errors keep popping up.
I did not have any such problem in old server.
I checked the resolver file and the nameservers are set on Google's DNS
