[deleted] https://domain:887/phpmyadmin_20c6de13510b30ea/index.php Nothing shows up, this is running in aapannel side, i can see the settings in place for nginx, the page does not work .
[deleted] aaPanel_Jose There is rule open in firewall for 888, i changed the port from 887 to 888 it seems that when enabling SSL, alto SSL is in place its not going to be used by phpmyadmin nginx config.
[deleted] I think its also issue in default config: since is not running ssl by default, it seems it cannot use SSL, and my domain is on HSTS.
aaPanel_Jose [deleted] After ssl is turned on, the configuration file is in this location /www/server/panel/vhost/nginx/phpmyadmin.conf
N1on just delete /index.php in URL. its bug of aaPanel. In PhpMyAdmin section link without /index.php and it's work! But when you press button PhpMyAdmin in section Databases - you go to browser with link that ending /index.php - and it's doesn't work, link is incorrect. @aaPanel_Jose please fix this
Romeo Hello, I think after Setting a domain name for aaPanel, phpMyAdmin goes inaccessible. So as a remedy I suggest you test phpMyAdmin link with server IP instead of specified domain name. for example: https://255.255.255.255:888/phpmyadmin_0000000000000000/index.php I think this trick will work well and probably there is no need to disable HSTS settings and rules... thanks for your good guidance.
