• Support
  • react js project in node projects isssue
even after stoping the react project its still running on domain also when updating and restarting its not updating running old only after server rerstart then its updating
    Hello, please check if there is any process running? You can use the ps aux command to check
    aaP_kc901789
    5 days later
    still not its issue onnly in react js project on npm run dev
    noe even on server restarting it not updating running on ip:300 port updated but in domain its showing old
