Hi Team,
Tried running the given command but with no help. Below is the output.
[root@CRM-TechaDox ~]# rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 36200 100 36200 0 0 608k 0 --:--:-- --:--:-- --:--:-- 609k
Python3.12 No upgrade required
[notice] A new release of pip is available: 24.0 -> 24.2
[notice] To update, run: /www/server/panel/pyenv/bin/python3.12 -m pip install --upgrade pip
bash: line 838: [: : integer expression expected
File "/www/server/panel/tools.py", line 20, in <module>
import public,time,json
File "/www/server/panel/class/public/init.py", line 14, in <module>
from .common import *
File "/www/server/panel/class/public/common.py", line 4, in <module>
import json, os, sys, time, re, socket, importlib, binascii, base64, io, string, psutil
ModuleNotFoundError: No module named 'psutil'
--2024-08-30 05:11:14-- https://node.aapanel.com/install/update/LinuxPanel_EN-7.0.8.zip
Resolving node.aapanel.com (node.aapanel.com)... 172.67.171.7, 104.21.79.196, 2606:4700:3031::6815:4fc4, ...
Length: 32267576 (31M) [application/zip]
Saving to: ‘/tmp/panel.zip’
100%[=============================================================================================>] 32,267,576 107MB/s in 0.3s
2024-08-30 05:11:15 (107 MB/s) - ‘/tmp/panel.zip’ saved [32267576/32267576]
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
Starting Bt-Panel............failed
done
Starting Bt-Tasks... failed
from psutil import Process, pids, cpu_count, cpu_percent, net_io_counters, disk_io_counters, virtual_memory
File "/www/server/panel/BT-Task", line 13, in <module>
import task
File "/www/server/panel/task.py", line 20, in <module>
import task
import task
Successfully upgraded to[7.0.8]
