Hello..
My redis successfully installed and running but gui not work when I will setting.
What should I do to fix this problem?
    Hello, it is recommended that you check the installation log, which is caused by the file not being downloaded successfully. Is it possible to try reinstalling?
    octocat
    I have tried reinstalling several times, but the result is still the same.
    I will try reinstalling one more time and will send you the log.
    aaPanel_Kern Server located in Jakarta, Indonesia.
    Redis successfully install, but i cant start n filled performance setting.
