nginx: [alert] failed to load the 'resty.core' module (https://github.com/openresty/lua-resty-core); ensure you are using an OpenResty release from https://openresty.org/en/download.html (reason: module 'resty.core' not found:
no field package.preload['resty.core']
no file '/www/server/nginx/lib/lua/resty/core.lua'
no file './resty/core.lua'
no file '/usr/local/share/luajit-2.1.0-beta3/resty/core.lua'
no file '/usr/local/share/lua/5.1/resty/core.lua'
no file '/usr/local/share/lua/5.1/resty/core/init.lua'
no file './resty/core.so'
no file '/usr/local/lib/lua/5.1/resty/core.so'
no file '/usr/local/lib/lua/5.1/loadall.so'
no file './resty.so'
no file '/usr/local/lib/lua/5.1/resty.so'
no file '/usr/local/lib/lua/5.1/loadall.so') in /www/server/nginx/conf/nginx.conf:104
Nginx failed to start and the error message appeared on Almalinux 8 fresh install
