Adrian Hello, I received this error when I pressed phpinfo in the settings; what is or how can I solve this?
aaPanel_Kern Adrian Hello, please execute this command to check if there are any errors or warnings? /www/server/php/81/bin/php -c /www/server/php/81/etc/php.ini /www/server/panel/class/php_info.php
aaPanel_Kern Adrian Sorry yours is openlitespeed should use this /usr/local/lsws/lsphp81/bin/php -c /usr/local/lsws/lsphp83/etc/php/8.1/litespeed/php.ini /www/server/panel/class/php_info.php
aaPanel_Kern Hello, it prompts that there is an error loading the xdebug extension. It is recommended that you check whether the configuration file and extension exist. Adrian
Adrian aaPanel_Kern Yes, the xdebug extension was installed and that's why it was doing that, I uninstalled it and now it works normally. Thank you!
