Summary: My php sites are not showing up, just the error "File not found.".
I recently installed aaPanel because I needed to host multiple sites, issue. Everything was working fine until I had to use php, any .php file I tried to open returns the same message "File not found.". I have tried many configurations, other versions of php and I get the same error. All I did was install what the panel suggested (php, apache, etc.).
In the site logs I get the following error
"[proxy_fcgi:error] [pid 267647:tid 267770] [client 192.168.1.10:9450] AH01071: Got error 'Primary script unknown'"
My configuration is the default one given to me by the panel
<VirtualHost *:99>
ServerAdmin webmaster@example.com
DocumentRoot "/www/wwwroot/------.com"
ServerName ------.-----.com
ServerAlias francogiovanni.com
#errorDocument 404 /404.html
ErrorLog "/www/wwwlogs/------.com-error_log"
CustomLog "/www/wwwlogs/------.com-access_log" combined#DENY FILES
<Files ~ (.user.ini|.htaccess|.git|.env|.svn|.project|LICENSE|README.md)$>
Order allow,deny
Deny from all
</Files>
#PHP
<FilesMatch .php$>
SetHandler "proxy:unix:/tmp/php-cgi-80.sock|fcgi://localhost"
</FilesMatch>
#PATH
<Directory "/www/wwwroot/------i.com">
SetOutputFilter DEFLATE
Options FollowSymLinks
AllowOverride All
Require all granted
DirectoryIndex index.php index.html index.htm default.php default.html default.htm
</Directory>
</VirtualHost>and in my .htaccess I have nothing
