• Support
  • Firewall - Import IP Rules - RecursionError: maximum recursion depth exceeded
After the last update, I get this error when blocking IP addresses separated by , or importing them with a json file in the firewall.
I also get this error when I try to add them one by one from the point I pointed out in the image below.
I need urgent help. Thanks in advance.
    Thanks. I was able to add it before. I added it from where you said before. I always go back to where I involuntarily threw this screenshot in the panel menu.
