Hello, sorry for your bad experience Cron tasks [Do not delete] breaking through check task security -- Brute force protection needs to be used
This issue will be optimized in the next version, This task does not run the ps command.
719 * * * * *
It should be injected in other ways, suggesting that you check if the server has a security problem and whether the running program has a loophole
