i have laravel 10 project that installed to aaPanel (Nginx, PHP 8.3). after some installation following aapanel forum, my website finally live, but with normal path (https://sub.domain.com).
But, in my case, i want this laravel project live in subpath ( target: https://sub.domain.com/laravel/project_name
). And it's work, BUT. only work route home ( `url('/')' ), and all the local assets (css,js,etc) 404 not found.
here's what i tried
server
listen 80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
listen [::]:80;
server_name sub.domain.com;
root /www/wwwroot/sub.domain.com/public;
#error_page 404/404.html;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite ^(/.*)$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/sub.domain.com/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/sub.domain.com/privkey.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
error_page 404 /404.html;
error_page 502 /502.html;
#ERROR-PAGE-END
include enable-php-83.conf;
#PHP-INFO-END
location /laravel/project_name {
alias /www/wwwroot/sub.domain.com/public;
try_files $uri $uri/ @laravel;
location ~ \.php$ {
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_pass unix:/tmp/php-cgi-83.sock;
location @laravel {
rewrite /laravel/project_name/(.*)$ /laravel/project_name/index.php?/$1 last;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.env|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
#Prohibit putting sensitive files in certificate verification directory
if ( $uri ~ "^/\.well-known/.*\.(php|jsp|py|js|css|lua|ts|go|zip|tar\.gz|rar|7z|sql|bak)$" ) {
return 403;
expires 30d;
error_log /dev/null;
access_log /dev/null;
location ~ .*\.(js|css)?$
expires 12h;
access_log /www/wwwlogs/sub.domain.com.log;
error_log /www/wwwlogs/sub.domain.com.error.log;
Like i said, only work for /
route/url, and all the assets are 404 not found for https://sub.domain.com/laravel/project_name
, all the assets still on default subdomain https://sub.domain.com/
Thanks
