I have turned off the firewall.
There is the dnschecker result
And the error when I ran "bt 22"
EXECUTING
rep1 = "\d{1,5}(:\d{1,5})?$"
/www/server/panel/class/safeModel/firewallModel.py:375: SyntaxWarning: invalid escape sequence '\d'
rep2 = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/class/safeModel/firewallModel.py:437: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:495: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:628: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/class/safeModel/firewallModel.py:1460: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1931: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1936: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1996: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:2008: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:2519: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,5}(:\d{1,5})?$"
/www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
task_thread.setDaemon(True)
Exception in thread Thread-230 (_thread):
File "/www/server/panel/pyenv/lib/python3.12/threading.py", line 1073, in bootstrap_inner
self.run()
File "/www/server/panel/pyenv/lib/python3.12/threading.py", line 1010, in run
self.target(self.args, **self.kwargs)
File "/www/server/panel/class/simple_websocket/ws.py", line 169, in thread
self.connected = self.handle_events()
File "/www/server/panel/class/simple_websocket/ws.py", line 249, in handle_events
self.sock.send(out_data)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/socketcommon.py", line 725, in send
return self.sock.send(data, flags)
BrokenPipeError: [Errno 32] Broken pipe
[2024-08-14 11:25:52][DEBUG] - 进入检查ip--all
[2024-08-14 11:25:55][DEBUG] - 进入检查ip--all
Exception in thread Thread-344 (thread):
self.run()
Exception in thread Thread-48 (thread):
self.run()
Exception in thread Thread-1261 (thread):
self.run()
Exception in thread Thread-1281 (thread):
self.run()
self.target(*self.args, **self.kwargs)
return self._sock.send(data, flags)
BrokenPipeError: [Errno 32] Broken pipe`
