inguide Switch version does not work. Mysql 8.0 Mysql 9.0 Mysql maiadb_10.00 It should switch when I select from, but it does not switch. It is aapanel v7.07. Please check. Thank you.
aaPanel_Kern It is recommended that you check the installation log to see what caused the problem /tmp/panelExec.log inguide
inguide aaPanel_Kern Could you please check? I used mysql and installed maiadb by cross-selection, but it didn't work, so I deleted mysql and installed maiadb. https://barodown.com//?dl=1c20e6a1608194687c3f54b63ac46538
aaPanel_Kern Check from the log that the installation was successful. If you cannot switch, do you get a message?
