aaPanel_Jose On the other hand, I don't have a screenshot because what I'm mentioning no longer exists. Before there were two options, one said "Secure access to MySQL through the control panel" and the other said "Normal access through login".
Coincidentally, the first option to access disappeared. Now when you give Manager in a certain DB, instead of showing you a box to select the login mode, it only comes directly to the PhpMyAdmin login
