Hi in previous version (6.x) of aapanel it was simple to modify the panel interface desgin or other things for developing perpose but in 7.x version there are compiled js files ... Is there any way to modify and build this compiled js?
If possible then please also share about it.
Thank you.
    Hello, is there any problem that needs to be corrected? Or do you need to add any functions?
    Currently, the interface is rewritten using vue3, which is difficult to modify after compilation.
    aaP_fihaca9352
      There is no problem in this pannel. This pannel is the Best.
      But I want to make my own custom changes and add some more function๐Ÿ˜Š but changing this compiled js is hard.
      I also checked the aaPanel's GitHub repository but there is also the compiled JS ๐Ÿ˜‘.
        Connect with us: ๐Ÿ“จ Telegram ๐Ÿ’ฌ Discord Email: support@aapanel.com
