aaP_mdestafadilah_simrs still exist but my apps is running well. sometime when typed in terminal, any clue kern?
aaPanel_Kern Hello, have you modified the configuration of php? These extensions are not available by default and you need to install them yourself. If they are built-in extensions, you do not need to enable the configuration. aaP_mdestafadilah_simrs
aaPanel_Kern Hello, these extensions are not available by default. Didn't you install this yourself? aaP_mdestafadilah_simrs
aaP_mdestafadilah_simrs aaPanel_Kern no just enable in here if extension not avaliable why i can use it. or i'm something missing? it's show after upgrade panel version.
