• Support
  • Bypass Chars limit or domains.
Hello guys,
i was using aapanel correctly until there was a domain chars limit..
How can i edit aapanel to avoid having this limit ?
Thanks
Best Regards!
    Hello,
    vmjfieomxhnfjba57sd6jjws2ogvowjgxhhfglsikqvvrnrajbmpxqqd.onion
    (I'm currently using aapanel with tor domains)
    Hello, it is recommended that you use a normal domain name to add it. Such a domain is not supported for the time being.
    Hello,
    could you please let me know where to edit file so i can increase chars limit ?
    Thanks
