oneglash aaPanel_Kern ileinfo.sh: line 93: ./configure: No such file or directory make: *** No targets specified and no makefile found. Stop. error
oneglash aaPanel_Kern got the solution need to install sudo apt-get install php-dev and then it will work
aaP_demo1 oneglash Please go to Mail Server on App Store > Service Status and Click on Repair Dovecot, Rspamd and Postfix service if it helps.
aaPanel_Kern oneglash Hello, is the problem solved? Is it possible to add any mailbox to the Mail Server Blacklist in the menu on the left and then delete it?
aaP_demo1 oneglash Check your TXT records contains default._domainkey once again to see if it is not correct value from the Mail Server Domain DKIM Verification Prompt.
aaP_demo1 oneglash Try to enable SSL on mail server, then test mail sending. if it fails, try remove the email account and add a new one then try send mail again. If it does not work, check your mail server logs to see the problems.
oneglash aaP_demo1 you know what is the issues , ? the issues with AApanel , they are not accepting it but from whenever they update V7 the issues started all the time some issues you will see while installing it . But the are not working on it to fix they need to keep check this issues
oneglash aaP_demo1 now i am moving to cyberpanel which is easy to use and with no issues yet with any thing PHP working fine mail server fine hosting working fine
aaP_demo1 oneglash I did fresh installation from my Debian 12 server with v7.x.x . it's smooth as lubes. I understand the issues around it. The workaround is quite repetitive. I'm working on aaPanel for testing for a year now. it seems that you have to be patient with this panel in order to make it fully manageable.
aaP_demo1 oneglash sure, you can choose what panel can satisfy you better. but, aaPanel provides more robust and features whenever you need. Plus, they're introducing more feature into the panel too.
