Change Log:
- Add WP Toolkit Integrity check function
- Add WP Toolkit plug-in management
- Add WP Toolkit Themes management
- Optimize WP Toolkit page
- Optimize some code warning issues
- Fix the issue where Curl warning caused the inability to apply for SSL
- Fix Quota issues for Website, FTP, Databases
- Fix file interface display problem on mobile terminal
- Fix some known issues
Tip: After upgrading, please press Ctrl + F5 to force refresh
This version will be updated to Python 3.12, please read this post before updating:
aaPanel operating environment upgrade to Python 3.12 Questions and answering
If you encounter problems during use:
- Take a screenshot of the error message,
- Provide the operating system and system version you are using and provide feedback to the forum.
