I cannot reach the panel. The url:port does not work. This stopped suddenly, after 2 years. What can I do? I can logon with SSH.
    Hello, can you use the command to check if there are any errors?
    curl -k https://www.aapanel.com/script/aapanel_check.sh | bash
    ta_ihpoj1jophi_at
    Here the result:
    % Total % Received % Xferd Average Speed Time Time Time Current
    Dload Upload Total Spent Left Speed
    100 5818 100 5818 0 0 11124 0 --:--:-- --:--:-- --:--:-- 11103
    Bt-Panel (pid 3127) already running
    Bt-Task (pid 2555) already running
    webserver 3158 root 7u IPv4 2102416928 0t0 UDP *:8889
    Getting server ip, Please wait...
    aaPanel port external network CORRECT 8889 test access is normal
    SSL is enabled, please use HTTPS access
    aaPanel Internet Address: CORRECT
    aaPanel Internal Address: https://CORRECT:8889/login
    When sharing, please be careful to hide your IP address
    Server internal 127.0.0.1 test access is normal
    -------------------------Disk space usage--------------------------
    Filesystem Size Used Avail Use% Mounted on
    /dev/ploop30534p1 317G 22G 283G 7% /
    none 4.2G 0 4.2G 0% /sys/fs/cgroup
    none 4.2G 0 4.2G 0% /dev
    tmpfs 4.2G 13k 4.2G 1% /dev/shm
    tmpfs 839M 1.3M 838M 1% /run
    tmpfs 5.3M 0 5.3M 0% /run/lock
    none 4.2G 0 4.2G 0% /run/shm
    tmpfs 839M 0 839M 0% /run/user/0
    --------------------------Inode usage------------------------------
    Filesystem Inodes IUsed IFree IUse% Mounted on
    /dev/ploop30534p1 19660800 215315 19445485 2% /
    none 1024000 17 1023983 1% /sys/fs/cgroup
    none 1024000 75 1023925 1% /dev
    tmpfs 1024000 4 1023996 1% /dev/shm
    tmpfs 1024000 285 1023715 1% /run
    tmpfs 1024000 4 1023996 1% /run/lock
    none 1024000 1 1023999 1% /run/shm
    tmpfs 1024000 20 1023980 1% /run/user/0
    Python version: Python 3.12.3
    aaPanal version_o: 7.0.6
    I tried to login with "private window" and that worked. the thing is, that AUTO-update of SSL-certificates does not work anymore. This was the reason for the problem with the certificate. I don't know how to re-activate auto-update of SSL-certificates.
    Hello, will cron not run automatically? Please check the logs of related tasks.
    Or check the cron program log
    Debian/ubuntu:
    systemctl status cron
    Centos:
    systemctl status crond
    ta_ihpoj1jophi_at
    Randomly, I find lines like this, in aapanel / Cron / Task list / Renew Let’s Encrypt Certificate / Log:
    /www/server/panel/class/acme_v2.py:1355: DeprecationWarning: X509Extension support in pyOpenSSL is deprecated. You should use the APIs in cryptography.
    /www/server/panel/class/acme_v2.py:722: SyntaxWarning: invalid escape sequence '\.'
      'if ($request_uri ~ "^/\.well-known/acme-challenge/{}.*"){{\n'
    /www/server/panel/class/acme_v2.py:931: SyntaxWarning: invalid escape sequence '\s'
      return public.get_msg_gettext("Issuance failed, the root domain name of domain name %s exceeds the maximum weekly issuance limit!" % re.findall("hours:\s+(.+?),", error))
      File "/www/server/panel/class/acme_v2.py", line 792, in save_cert
        pfx_buffer = self.dump_pkcs12(
      File "/www/server/panel/class/acme_v2.py", line 977, in dump_pkcs12
        p12 = OpenSSL.crypto.PKCS12()
      File "/www/server/panel/pyenv/lib/python3.12/site-packages/cryptography/utils.py", line 72, in __getattr__
        obj = getattr(self._module, attr)
    AttributeError: module 'OpenSSL.crypto' has no attribute 'PKCS12'
      aaPanel_Kern This script was not created by me. The cron job was recognized today, after exploring the issues. It seems to be that the job checks daily if one or more of the certificates should be renewed. I’m not sure what I should fix.
      Should I fix the python script? Or should I hit the “fix”-link?
      After my manual renewal for all the domains, the script was started. It showed that at the log:
      ★[2024-07-17 18:57:51] Successful
      /www/server/panel/class/acme_v2.py:722: SyntaxWarning: invalid escape sequence '.'
      'if ($request_uri ~ "^/.well-known/acme-challenge/{}.*"){{\n'
      |-No SSL certificate found within 30 days!
      |-All tasks have been processed!
      I started now the script again, and it just said: [2024-07-18 02:28:08] Successful
      Btw, with manual renewal, I referred to aapanel / Website / Site Name / SSL / Disable + Let’s Encrypt + Select several Domain names + Apply.
