Hello, after updating 7.0.6 and I see the runs log, is this normal?? how to downgrade back to the previous version
File "/www/server/panel/pyenv/lib/python3.12/threading.py", line 1073, in bootstrap_inner
self.run()
File "/www/server/panel/pyenv/lib/python3.12/threading.py", line 1010, in run
self.target(self.args, **self.kwargs)
File "/www/server/panel/class/simple_websocket/ws.py", line 169, in thread
self.connected = self.handle_events()
File "/www/server/panel/class/simple_websocket/ws.py", line 249, in handle_events
self.sock.send(out_data)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/socketcommon.py", line 725, in send
return self.sock.send(data, flags)
/www/server/panel/BT-Panel:63: SyntaxWarning: invalid escape sequence '\c'
os.system("\cp -f {} {}".format(plugin_loader_src_file, plugin_loader_file))
/www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
task_thread.setDaemon(True)
/www/server/panel/class/logsModel/panelModel.py:201: SyntaxWarning: invalid escape sequence '\s'
if username and not re.search('-\s+({})\s+('.format(username),line):
[2024-07-11 13:22:12][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-11 13:22:23][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-11 13:22:38][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-11 13:22:46][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-11 20:50:21][DEBUG] - v2-get_config
[2024-07-11 23:59:02][DEBUG] - {"id": 2, "path": "/www/wwwroot/payplaz.com/public_html"}
[2024-07-12 04:51:05][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 04:51:21][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 04:51:32][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 04:51:43][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 04:51:54][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 04:52:04][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
/www/server/panel/class_v2/btdockerModelV2/setupModel.py:112: SyntaxWarning: invalid escape sequence '\s'
docker_conf = re.sub("SAVE\s=\s\d+", "SAVE={}".format(save_date),
/www/server/panel/class_v2/btdockerModelV2/composeModel.py:49: SyntaxWarning: invalid escape sequence '\c'
public.ExecShell("\cp -r {} /tmp/{}.yml".format(path, public.md5(path)))
/www/server/panel/class_v2/btdockerModelV2/composeModel.py:373: SyntaxWarning: invalid escape sequence '\s'
template_container_name = re.findall("container_name\s:\s[\"\']+(.)[\'\"]", template_data)
/www/server/panel/class_v2/btdockerModelV2/composeModel.py:384: SyntaxWarning: invalid escape sequence '\d'
rep = "(\d+):\d+"
/www/server/panel/class/safeModel/firewallModel.py:344: SyntaxWarning: invalid escape sequence '\d'
rep1 = "\d{1,5}(:\d{1,5})?$"
/www/server/panel/class/safeModel/firewallModel.py:375: SyntaxWarning: invalid escape sequence '\d'
rep2 = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/class/safeModel/firewallModel.py:437: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:495: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:628: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}(\/\d{1,2})?$"
/www/server/panel/class/safeModel/firewallModel.py:1460: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1931: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1936: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:1996: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:2008: SyntaxWarning: invalid escape sequence '\d'
/www/server/panel/class/safeModel/firewallModel.py:2519: SyntaxWarning: invalid escape sequence '\d'
rep = "\d{1,5}(:\d{1,5})?$"
[2024-07-12 10:56:48][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 12:23:43][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 15:48:25][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 15:48:35][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 15:48:48][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 15:48:59][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 15:50:05][DEBUG] - v2-get_config
[2024-07-12 15:50:09][DEBUG] - v2-get_config
[2024-07-12 16:14:08][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
[2024-07-12 16:14:23][DEBUG] - error info: 'NoneType' object has no attribute 'validate'
