024-07-11T04:12:45.649885Z 0 [ERROR] [MY-013183] [InnoDB] Assertion failure: log0write.cc:2115:ib::fatal triggered thread 7912504166080
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/8.0/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
2024-07-11T04:12:45Z UTC - mysqld got signal 6 ;
Most likely, you have hit a bug, but this error can also be caused by malfunctioning hardware.
BuildID[sha1]=7bb83e904644d700b0aec8fda7e2b1c5495ab04d
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0 thread_stack 0x100000
/www/server/mysql/bin/mysqld(my_print_stacktrace(unsigned char const, unsigned long)+0x41) [0x5fbe0abffb91]
/www/server/mysql/bin/mysqld(print_fatal_signal(int)+0x3b7) [0x5fbe0a29b677]
/www/server/mysql/bin/mysqld(my_server_abort()+0x6d) [0x5fbe0a29b6fd]
/www/server/mysql/bin/mysqld(my_abort()+0xe) [0x5fbe0abfa71e]
/www/server/mysql/bin/mysqld(ut_dbg_assertion_failed(char const, char const, unsigned long)+0x17e) [0x5fbe0adb813e]
/www/server/mysql/bin/mysqld(ib::fatal::fatal()+0x95) [0x5fbe0adce6b5]
/www/server/mysql/bin/mysqld(+0x16d95e7) [0x5fbe0ace35e7]
/www/server/mysql/bin/mysqld(+0x16d9f77) [0x5fbe0ace3f77]
/www/server/mysql/bin/mysqld(log_writer(log_t)+0x528) [0x5fbe0ace5428]
/www/server/mysql/bin/mysqld(+0x16d3879) [0x5fbe0acdd879]
/lib/x86_64-linux-gnu/libstdc++.so.6(+0xeabb4) [0x732cd2eabb4]
/lib/x86_64-linux-gnu/libc.so.6(+0x9ca94) [0x732cce9ca94]
/lib/x86_64-linux-gnu/libc.so.6(+0x129c3c) [0x732ccf29c3c]
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
2024-07-11T10:51:23.349658Z 0 [Warning] [MY-000081] [Server] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824.
2024-07-11T10:51:23.349681Z 0 [Warning] [MY-011070] [Server] 'binlog_format' is deprecated and will be removed in a future release.
2024-07-11T10:51:23.349708Z 0 [Warning] [MY-010915] [Server] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2024-07-11T10:51:23.349741Z 0 [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
2024-07-11T10:51:23.349750Z 0 [System] [MY-010116] [Server] /www/server/mysql/bin/mysqld (mysqld 8.0.36) starting as process 1648223
2024-07-11T10:51:23.443965Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=4294967296. Please use innodb_redo_log_capacity instead.
2024-07-11T10:51:23.444664Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-07-11T10:51:24.884109Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2024-07-11T10:51:24.925867Z 0 [ERROR] [MY-011300] [Server] Plugin mysqlx reported: 'Setup of socket: '/tmp/mysqlx.sock' failed, can't open lock file /tmp/mysqlx.sock.lock'
2024-07-11T10:51:25.086939Z 0 [System] [MY-010229] [Server] Starting XA crash recovery...
2024-07-11T10:51:25.129156Z 0 [System] [MY-010232] [Server] XA crash recovery finished.
2024-07-11T10:51:25.323174Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2024-07-11T10:51:25.323198Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2024-07-11T10:51:25.323383Z 0 [ERROR] [MY-010274] [Server] Could not open unix socket lock file /tmp/mysql.sock.lock.
2024-07-11T10:51:25.323391Z 0 [ERROR] [MY-010268] [Server] Unable to setup unix socket lock file.
2024-07-11T10:51:25.323396Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-07-11T10:51:26.270949Z 0 [System] [MY-010910] [Server] /www/server/mysql/bin/mysqld: Shutdown complete (mysqld 8.0.36) Source distribution.
