sanhpv aaPanel_Kern I click save many times but still disabled redis installed in aapanel, can anyone help me
aaPanel_Kern Does redis set a password? Is the plug-in used by this website the same server as redis? sanhpv
sanhpv aaPanel_Kern If I connect using the plugin it works, but I don't want to download the redis plugin, I add it to litespeed but it doesn't work
aaPanel_Kern It is recommended that you check whether the redis configuration has a password configured? Does litespeed's configuration support password configuration? Are they all on the same server? sanhpv
sanhpv aaPanel_Kern I tried installing the separate redis plugin and it connected successfully, while Object litespeed was disabled, confusingly.
