aaP_fjrspl99 hello, i want to add site with port 88 , but i can't add that port because port range is incorrect, any solution?
aaPanel_Kern Hello, thank you for your feedback. This is a BUG. You can add the site directly using the IP first, and then modify the configuration file to change port 80 to 88. Finally, go to the security interface to release port 88. aaP_fjrspl99
