aaP_webnatrix You need to install radisAdmin https://github.com/erikdubbelboer/phpRedisAdmin How to implement it so that it opens on the way IP😛ORT/phpRedisAdmin_s123nskds Where do I need to write something that would refer to the folder? /www/server/phpredisadmin
aaPanel_Kern Hello, it is recommended that you directly use the ip+port method to create the site, and then enter the website directory and deploy it manually according to the tutorial. The way to establish a site using IP+port is: 1.1.1.1:96 aaP_webnatrix
