alphabyte After I installed phph 7.3 I try to install wordpress with "one click deployment" appilcation but is not working. I receive the error message "Missing supported PHP version, please install". How can I solve this problem ? Any suggestion ? Thanks !!!
kaz050457 aaPanel_Jose how to update on our current installation.If you do small fixing and we wanted to apply it on our panel.
aaPanel_Jose kaz050457 if the plugin has update in the future, we will release the plugin version , you only need to click the update button.. 😀
