Hello, I’m having trouble accessing the panel and I’m not sure what’s causing the issue. I keep getting 404 Not Found
error.
Error logs
root@vps:~# bt 22
EXECUTING
self.init_socket()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/pywsgi.py", line 1668, in init_socket
StreamServer.init_socket(self)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/server.py", line 173, in init_socket
self.socket = self.get_listener(self.address, self.backlog, self.family)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/server.py", line 185, in get_listener
return _tcp_listener(address, backlog=backlog, reuse_addr=cls.reuse_addr, family=family)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/server.py", line 264, in tcp_listener
sock.bind(address)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/socketcommon.py", line 547, in bind
return self._sock.bind(address)
OSError: [Errno 98] Address already in use: ('0.0.0.0', 7800)
- Serving Flask app 'BTPanel'
- Debug mode: off
Port 7800 is in use by another program. Either identify and stop that program, or start the server with a different port.
/www/server/panel/BT-Panel:63: SyntaxWarning: invalid escape sequence '\c'
os.system("\cp -f {} {}".format(plugin_loader_src_file, plugin_loader_file))
/www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
task_thread.setDaemon(True)
[2024-07-04 11:30:53][WARNING] - ('Starting BaoTa web server...Failed to start BaoTa web server\n', 'nginx: [emerg] bind() to 0.0.0.0:7800 failed (98: Address already in use)\nnginx: [emerg] bind() to 0.0.0.0:7800 failed (98: Address already in use)\nnginx: [emerg] bind() to 0.0.0.0:7800 failed (98: Address already in use)\nnginx: [emerg] bind() to 0.0.0.0:7800 failed (98: Address already in use)\nnginx: [emerg] bind() to 0.0.0.0:7800 failed (98: Address already in use)\nnginx: [emerg] still could not bind()\n')
[2024-07-04 11:30:53][ERROR] - Web server start failed.
[2024-07-04 11:30:53][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/BT-Panel", line 352, in <module>
http_server.serve_forever()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/baseserver.py", line 398, in serve_forever
self.start()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/baseserver.py", line 336, in start
self.init_socket()
sock.bind(address)
root@vps:~# sudo lsof -i :7800
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nginx 1659 root 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1660 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1661 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1662 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1663 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1664 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
nginx 1665 www 31u IPv4 26940 0t0 TCP *:7800 (LISTEN)
webserver 7085 root 7u IPv4 107092 0t0 UDP *:7800
webserver 7085 root 8u IPv6 107094 0t0 TCP *:7800 (LISTEN)
webserver 7085 root 9u IPv6 107095 0t0 UDP *:7800
root@vps:~#
