I upgraded panel to 7.0.5 using WEB, and after logging in again, get this error page. I have run 'bt 16' try to fix it. But it has no effect.
An error occurred while the panel was runningļ¼
An error occurred while the panel was running: failed to parse soft list, trying repair, please try again later.
REQUEST_DATE: 2024-07-02 18:38:45
VERSION: CentOS Stream 8 x86_64(Py3.12.3) - 7.0.5
REMOTE_ADDR: 106...*
REQUEST_URI: GET /?
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/BTPanel/init.py", line 565, in index_new
100])], data['pro_end'], data['ltd_end'] = get_pd()
File "/www/server/panel/BTPanel/init.py", line 2552, in get_pd
return public.get_pd()
File "/www/server/panel/class/public/init.py", line 3931, in get_pd
plugin_list = load_soft_list()
File "/www/server/panel/class/public/init.py", line 8147, in load_soft_list
raise PanelError(str(plugin_list_data['msg']))
public.PanelError: An error occurred while the panel was running: failed to parse soft list, trying repair, please try again later.
Sorry, an unexpected error occurred while the panel was running. Please try to resolve this error in the following order:
- Click the Fix button in the upper right corner of [Home], and log out of the panel and log in again.
- Still unresolved, please take a screenshot of this window and post on the forum for help, address:https://www.aapanel.com/forum/
