nikokenzo I Have successfully installed Aapanel on Rockylinux 9. But the problem is when I try install LAMP, Apache 2.4 wont installed. what happened? can someone help it to install? Also try repeat manually from Appstore, but always failed or not installed
aaPanel_Kern It is recommended that you check the installation log and check the installation error log /tmp/panelExec.log nikokenzo
nikokenzo aaPanel_Kern https://pastebin.com/3FefHVhL this the log. installation for phpmyadmin also failed
