nikokenzo Dear admin please help me. after upgrading the aapanel into version 7.0.5 now my php script cannot works well. cannot login into my website etc. can you help me please
aaPanel_Kern Hello, upgrading aapanel will not do this. What is the prompt when it cannot be executed? Is it normal to use the command directly? nikokenzo
nikokenzo aaPanel_Kern i am trying re-install my apache and still cannot login into my website. i dont know why. i just can open first page of my website
nikokenzo aaPanel_Kern selecting download node... Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile base: mirror.aktkn.sg centos-sclo-rh: mirror.aktkn.sg epel: download.nus.edu.sg extras: mirror.aktkn.sg updates: mirror.aktkn.sg http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: (28, 'Connection timed out after 30001 milliseconds') Trying other mirror. http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: (28, 'Connection timed out after 30000 milliseconds') Trying other mirror. http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on https://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: (28, 'Connection timed out after 30527 milliseconds') Trying other mirror. http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://rspamd.com/rpm-stable/centos-7/x86_64/repodata/repomd.xml: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds') Trying other mirror. and this is now error cannot install apache again
aaPanel_Kern nikokenzo Hello. Is it possible to try to install using this command? mv /etc/yum.repos.d/rspamd.repo /etc/yum.repos.d/rspamd.repo_bak
nikokenzo aaPanel_Kern mv /etc/yum.repos.d/rspamd.repo /etc/yum.repos.d/rspamd.repo_bak yes i can. i have send you email can you check it out
aaPanel_Kern It is recommended that you do it first and then try to see if it can be installed normally. nikokenzo
nikokenzo aaPanel_Kern apache has been installed. but now my website still down. if it can acessed, i cant login
nikokenzo aaPanel_Kern still not. please check email and try login into my website. i think php not work or database? this problem happened after i update the aapanel
aaPanel_Kern Hello, this is determined by the website program or rewriting rules. It is recommended that you check what operations you have done. The upgrade of aapanel only processes aapanel and does not do anything to the website. nikokenzo
nikokenzo aaPanel_Kern thank you sir. seriously i never do anything, just update aapanel and then not work. before it i use it normaly
nikokenzo aaPanel_Kern Thank you for your help. I trying to move into another vps and trying using Almalinux as new OS. i think Centos already many problem since aapanel update. and i will move my website into new aapanel for fresh install
