aaPanel_Kern Hello, I suggest you find phpmyadmin in the app store and enable SSL Or use the correct protocol to access aaP_work100cu
aaP_work100cu aaPanel_Kern Did it open automatically when I installed aapanel? It's still open now but still can't get in
aaPanel_Kern Are other programs using this port? What version of aapanel are you using? aaP_work100cu
aaP_work100cu aaPanel_Kern I use the latest version of aapanel: 7.0.4, how do I know if other utilities run the same port?
aaP_work100cu aaPanel_Kern let me ask! I couldn't access phpmyadmin just now so I clicked on a few things like the photo Will it be affected?
