aaP_mdestafadilah_simrs it's show up after updated 7.0.4, i have other server using aapanel development status 7.2.1, has running smoothly. should my production server using it?
aaPanel_Kern Hello, is the problem solved? Is it normal to try restarting the panel? Also check if the server can connect to our node server? restart panel: bt restart curl -v https://brandnew.aapanel.com ping brandnew.aapanel.com -c 5 ping google.com -c 5 curl -v http://brandnew.aapanel.com aaP_mdestafadilah_simrs
