Hi
Its is recommended to enable ModSecurity on OLS?
https://openlitespeed.org/kb/openlitespeed-modsecurity-module/
Hi
Cyberpanel has built-in into their modules. I didn't see this in aapanel
KrzysztofMaciejewski Hello, there is currently no inheritance of this extension, so if you need it, you may have to wait for it
aapanel_power Yea, i think if there is a feedback tool like fider, users can upvote the features. So aapanel team can understand which feature is most wanted and prioritize accordingly. Just a 2 cents.
+1
I try install it, but fatal error in aaPanel.
This is a server side configuration. Unfortunately, aaPanel configures everything on vHosts set on aaPanel. That's why your server crashes if you try to install it directly.
deewinc you're absolutely right. I tried setting it up but failed woefully many times. I hope aaPanel brilliant team are listening to help integrate this must-have feature (Modsecurity) in the future. This is one of the fantastic features on Cyberpanel.
