jxng Hello, Since updating to aaPanel 7, the phpMyAdmin option on databases page does not check whether the SSL setting is enabled or not, and it's always opening on the HTTP 888 port
jxng SSL is enabled correctly, as shown below But on service page, it shows the HTTP 888 URL And hitting phpMyAdmin on the databases page, will bring you to the HTTP 888 URL The SSL URL works normal tho, it's just a redirect bug on aaPanel
aaPanel_Kern Hello, thank you for your feedback. This problem has always existed and is not a BUG in the new version. It is recommended that you splice the access link yourself first. jxng
jxng aaPanel_Kern The thing is, it only started happening on version 7. I still have some servers on version 6 and they open the SSL port
aaPanel_Kern Hello, is SSL enabled? Is it the same if I use the browser in incognito mode or change the browser? jxng
