aaPanel_Jose TheBikramLama We haven't modified it yet. This could be a problem caused by incomplete installation. We will check the installation script. Thank you
Eazzy I have installed supervisor and rolled out a number of daemon, although the daemon are running i have no manually sometime restart the daemon to get the queue endpoint being consume? what could be the issue? number of processes = 15 priority is 1
aaPanel_Jose Depimios This problem is caused by spaces in the project name. You can modify the project name in the configuration file in the directory /www/server/panel/plugin/supervisor/profile and then it can be displayed Change aa fff to aafff
aaP_usmanwixpa I have same problem and I also install and uninstall several time. There is no space in name please answer
aaP_usmanwixpa aaPanel_Kern please suggest a solution how to resolve it. project address is => alpha-currency-converter-app.com
aaPanel_Kern aaP_usmanwixpa Hello, is the Supervisor normal? Your problem doesn't look like a supervisor's problem.
