pptik hello, i have some problem here, i have follow the intruction to activate lets encrypt ssl into aapanel dashboard, and i have restart panel, etc. so when i access it, it still show not secure. how to fix that? @aaPanel_Kern @aaPanel_Captain @aapanel_power
aaPanel_Kern Hello, yes, is it normal after saving? You can also check whether the contents of the /www/server/panel/ssl directory are successfully saved and consistent. pptik
pptik aaPanel_Kern i so confuse, i have save, so no idea its still show not secure, like this: and result from /www/server/panel/ssl directory is:
