Lucas_pereira After i login, the panel show me a modal with error, i'm try fix it with fix button on conner, but does not work, cam help me?
aaPanel_Kern Hello, is the problem solved? Is it normal to try restarting the panel? Also check if the server can connect to our node server? restart panel: bt restart curl -v https://brandnew.aapanel.com ping brandnew.aapanel.com -c 5 ping google.com -c 5 curl -v http://brandnew.aapanel.com Lucas_pereira
