Good afternoon everyone, I have several aapanel installed but now an error occurred that had never happened before.
I have the following error when installing pureftpd...
the information is the following
--2024-05-31 16:45:21-- https://node.aapanel.com/install/0/pureftpd.sh
Resolviendo node.aapanel.com (node.aapanel.com)... 172.67.171.7, 104.21.79.196, 2606:4700:3031::6815:4fc4, ...
Conectando con node.aapanel.com (node.aapanel.com)[172.67.171.7]:443... conectado.
Petición HTTP enviada, esperando respuesta... 200 OK
Longitud: 5838 (5,7K) [application/octet-stream]
Grabando a: “pureftpd.sh”
0K ..... 100% 35,4M=0s
2024-05-31 16:45:26 (35,4 MB/s) - “pureftpd.sh” guardado [5838/5838]
selecting download node...
--2024-05-31 16:45:59-- https://node.aapanel.com/src/mhash-0.9.9.9.tar.gz
Resolving node.aapanel.com (node.aapanel.com)... failed: Connection timed out.
wget: unable to resolve host address ‘node.aapanel.com’
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
lib.sh: line 202: cd: mhash-0.9.9.9: No such file or directory
lib.sh: line 203: ./configure: No such file or directory
make: *** No rule to make target `install'. Stop.
--2024-05-31 16:46:04-- https://node.aapanel.com/src/libmcrypt-2.5.8.tar.gz
lib.sh: line 154: cd: libmcrypt-2.5.8: No such file or directory
lib.sh: line 156: ./configure: No such file or directory
lib.sh: line 160: cd: libltdl/: No such file or directory
lib.sh: line 161: ./configure: No such file or directory
--2024-05-31 16:46:09-- https://node.aapanel.com/src/mcrypt-2.6.8.tar.gz
lib.sh: line 183: cd: mcrypt-2.6.8: No such file or directory
lib.sh: line 184: ./configure: No such file or directory
--2024-05-31 16:46:14-- https://node.aapanel.com/src/libiconv-1.14.tar.gz
mkdir: cannot create directory ‘/patch’: File exists
--2024-05-31 16:46:19-- https://node.aapanel.com/src/patch/libiconv-glibc-2.16.patch
lib.sh: line 134: cd: libiconv-1.14: No such file or directory
lib.sh: line 136: ./configure: No such file or directory
--2024-05-31 16:46:24-- https://node.aapanel.com/install/public.sh
Resolviendo node.aapanel.com (node.aapanel.com)... falló: Expiró el tiempo de conexión.
wget: no se pudo resolver la dirección del equipo “node.aapanel.com”
/src/pure-ftpd-1.0.49.tar.gz: Falta esquema.
tar (child): pure-ftpd-1.0.49.tar.gz: No se puede open: No existe el fichero o el directorio
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
pureftpd.sh: línea 48: cd: pure-ftpd-1.0.49: No existe el fichero o el directorio
Installing pure-ftpd...
pureftpd.sh: línea 51: ./configure: No existe el fichero o el directorio
make: *** No se especificó ningún objetivo y no se encontró ningún makefile. Alto.
pureftpd.sh: línea 56: GetSysInfo: no se encontró la orden
ERROR: pure-ftpd installation failed.
What can I do to solve it?
Regards
