mehadih31 It is showing 404 error after restarting the server from the panel dashboard for the last two days, what is the solution? Now I can no longer login to my panel
aaP_mdestafadilah_simrs mehadih31 it's your endpoint of aapanel access, are you trying login aapanel with IP Public or Domain name?
aaPanel_Kern Hello, is the problem solved? Please check if you use the full link to access the panel. Use the SSH tool to log in to the server and execute the command to view bt 14 mehadih31
aaP_mdestafadilah_simrs mehadih31 try login to your ssh with putty, or similar commandline to login aapanel, then change your port and enpoind like below with bt you can try like https://YOUR_IP_PUBLIC:YOUR_PORT/YOUR_ENTRANCE
mehadih31 aaPanel_Kern Thank You , Problem Solved, But Now Facing a new Problem . Permalink Error, 404 not found if you want then i can share my WP Logging Access
